20499 Posts in 2065 Topics- by 1413 Members - Latest Member: Cullens
November 22, 2017, 06:04:18 AM
Pages: [1]
Author Topic: Some tips to think about  (Read 590 times)
ctec4rxj
Sr. Member
« on: February 02, 2017, 08:30:26 AM »
1. Let someone know where you will be and when you expect to return. This applies to all trips, not just those in challenging areas. People have been known to get stuck or lost in relatively easy terrain. Should something happen and youíre unable to leave the area or call for help, your friends or family will know to contact authorities.
2. Always have at least one other vehicle along. This ensures that you will have transportation out in the event your vehicle becomes stuck or damaged and canít be fixed there. Plus, the extra vehicle means additional manpower to help with problems.
3. Pack survival gear. Even a Sunday drive on the beach can turn sour. Pack the proper gear to get you through the night and to handle medical emergencies that may occur. Remember to pack stuff tools that can help get you out.
4. Tie everything down inside. Your gear will go flying around if you roll over or lay the vehicle on its side. Loose items become missiles which can injure and kill anyone inside.
5. Everyone wears a seatbelt, just like when you drive on paved roads. You and your passengers will get jostled around quite a bit on many of the trails. Plus, the possibility for a rollover or crash exists at any time. The big rock you suddenly hit could cause you or your passengers to go flying out a window. Make sure everyone is belted in.
6. Arms and legs must remain inside. Many trails run through narrow passageways. Any arms or legs hanging outside can get torn off by the trees, cliff walls, or rocks just outside your vehicle. If the vehicle begins to tip your instinct is to put your hand out. There is no way you will be able to stop a vehicle this way. Roll your windows up if you canít control the urge.
7. Also, make sure no one holds onto the roll bar. Their fingers will get smashed in the event of a roll over. Hands can also be injured if you drive under low-hanging branches.
8. Quit if you become tired. Four-wheeling requires the utmost concen-tration. Any letdown can lead to an accident and perhaps death. If you feel fatigued at all, pull over and rest, or let someone else drive. Do not force it.
9. Lock it down. When driving off-road, you are seldom on level ground. Make sure your vehicle will not roll away from you. When you stop, put the vehicle in park, apply the emergency brake, and turn off the engine.
10. Do not hang on a vehicle. If the vehicle gets stuck in a precarious position, do not try to pull it down or otherwise tip it by hand. And absolutely do not climb on the vehicle. Use the proper tools and techniques, and always be a safe distance away. A vehicle can and will crush you if given the chance.
11. Treat winches and high-lift straps with respect. The straps, clevises, and other pieces are under extreme tension when in use. Inspect all parts before using, and stand clear while you are trying to recover a vehicle. A failure in gear or rigging can be lethal to you and by standers.
Devil Dog Racing - Semper FI - Carpe Diem
jp fan
Wheeler's Guild
ryan_hall@hotmail.com
« Reply #1 on: February 02, 2017, 12:36:43 PM »
Good tips man
Pages: [1]
